Go Back   HSTuners > Tech Talk > Interior Modifications
Old 01-08-2006, 11:34 PM   #1
water in trunk
I was cleaning out my trunk today and I lifted up the carpet to check out the spare tire well and there was water and rust in there. It has been dry weather here for 3 or 4 days and I don't know how long this has been going on. I am not sure where the problem is. I checked the weather seal around the trunk, and it looks fine. Anyone else have this trouble before? I am not sure what to look for as a cause. Any suggestions would be appreciated.
Thanks!
Old 01-09-2006, 05:44 AM   #2
Si-R CRX
I have to same problem in my CRX. I just pulled all my foam matting out of the back of mine 2 days ago and there was about an inch of water under it. Do you have a sunroof? Thats where mine is coming from. If you do check to be sure all of you sunroof drain lines are clear. If its not that then it is just the seal around it. Water can travel a good distance in the plastic of a car if the angles are right.
Si-R CRX is offline   Reply With Quote
Old 01-09-2006, 01:38 PM   #3
yea i got a sunroof. never thought to check it.
Old 01-09-2006, 01:47 PM   #4
Rob
Stefan's A Sheep Fucker
Rob's Avatar
Rob
thats why i use a sock.
Originally posted by MissJDM
Darin, please confirm that you don't like the cock!
HondaStyle.com Babysitter's Club Member #7
Anna Fan Club Member #1
Rob is offline   Reply With Quote
Old 12-16-2008, 11:47 PM   #5
samrawet
I think some problem in your trunk are you sure you check it very well check again if that is ok than check under the trunk I think there is some water
samrawet is offline   Reply With Quote
Old 07-27-2018, 08:21 AM   #6
Wolf21
The same thing happened to my ride. The leakage came from the bottom of the spare tire well.
Wolf21 is offline   Reply With Quote
Old 08-30-2021, 10:42 PM   #7
Ottozhao666
It's time for you to discover why PBN SEO are so powerful for your online business or startup. When you have a new network domain, you must gain authority compared to other websites with similar services. With PBNs and its well-defined structure, you gain popularity and emphasis over websites that provide the service.
website seo
Ottozhao666 is offline   Reply With Quote
