Go Back   HSTuners > Tech Talk > My Car is Broken!
Old 08-15-2006, 12:35 AM   #1
oil pressure sensor
so i put a new oil pressure sensor in my moms jeep becauase the old one was leaking. now when i turn it on the gauge jumps all the way up to 80 (the max) and doesnt go down.. what could my problem be?
Old 08-15-2006, 09:03 AM   #2
shorted wire somewhere?
Old 08-15-2006, 02:35 PM   #3
thats what i have been thinkin. but i cant see it just shorting now.
Old 08-15-2006, 03:09 PM   #4
first step is to unplug the wire. go from there
Old 08-15-2006, 03:58 PM   #5
will try that.
Old 10-11-2019, 02:12 AM   #6
namanjohnson101
HELLO EVRYONE,
The oil pressure sending unit is a common culprit. The correct thing to do here is put a manual gauge on it and see what the pressure really is but the sensors are pretty cheap and easy to replace so I usually just swap it for a new one.
That light tells you your car is having a heart attack. Hopefully it's just a sensor but you need to stop driving
REGARDS
namanjohnson101 is offline   Reply With Quote
Old 11-06-2019, 04:45 PM   #7
namanjohnson101
I hope my answer to this thread was helpful for people here in the forum
God bless us all
Regards
9apps apk cartoon hd
Old 09-02-2020, 04:22 AM   #8
roundcubefour
Standard oil pressure sensors work by displaying a warning signal when the oil pressure falls outside of the set range. Two important components to the oil pressure sensor include the spring-loaded switch and a diaphragm. ... The pressure switch is mounted onto the side of an engine block and wired to an oil gallery.
shareit vidmate vidmate app
roundcubefour is offline   Reply With Quote
Old 10-19-2020, 01:39 PM   #9
1unoevo8
1unoevo8's Avatar
God bless us all
Regards
1unoevo8 is offline   Reply With Quote
Old 03-27-2021, 11:42 AM   #10
bravesix
Multiple systems in your car are designed to maintain the correct engine oil level and pressure. ... The oil pressure sensor is hooked directly to the oil pressure gauge on your instrument cluster. When lower than normal oil pressure is detected, the pressure sensor will make the gauge in the car reflect this change.
bravesix is offline   Reply With Quote
Old 09-26-2021, 12:53 PM   #11
JustinBlack
If you can't solve your problem then you can hire an expert.
JustinBlack is offline   Reply With Quote
