Old 02-21-2006, 01:16 AM   #1
operating temp.
whats the operating temp. for a d15?
honda-tech doesnt help because i dont know who to believe on there. some say 180-190 some say 205-210 ??? my car is around 205 right now and the fans arnt kicking on. this is just idleing, i cant drive the car yet.
Old 02-21-2006, 02:08 AM   #2
sounds hot, i figure it shouldn't be too far from any other D motor although i may be mistaken. 185-190 is where most engines operate i think. Check your coolant temp switch.
Old 02-21-2006, 10:18 AM   #3
Si-R CRX
185-190 is about right.
Si-R CRX is offline   Reply With Quote
Old 02-21-2006, 10:25 AM   #4
nonovurbizniz
nonovurbizniz's Avatar
regardless of what the temperature SHOULD be the fans should be kicking on...
If they're not after 15-20 mins of idleing your coolant temp. sensor is prob. no good... to be sure its that jump the connector coming off the coolant temp sensor. If the fans come on then it's the sensor... if they don't then it's the fan motor.
I am an A$$hole... take anything I say to heart at YOUR OWN RISK...
nonovurbizniz is offline   Reply With Quote
Old 02-21-2006, 12:54 PM   #5
alright, ill check the sensor start small work big.
Old 02-21-2006, 01:08 PM   #6
i believe there's also other relays in that circuit as well, so don't go on the believe that it's either the sensor or the motor. But i may be wrong, and i'll check the service manual later when i have some time.
Old 02-21-2006, 03:14 PM   #7
plz check t he manual. i dont feel like wasting money on this DD i got.
Old 02-22-2006, 10:25 AM   #8
AkimboStylee
AkimboStylee's Avatar
just hard wire the fans to come on when the car starts
A very good quote : " I have many vices in my life, and those keep me from perfection, and not being perfect makes me a human being with morals" -Anonymous
AkimboStylee is offline   Reply With Quote
Old 02-22-2006, 11:53 AM   #9
Ok here's the way to test the ECT switch, per the honda service manual.
1. Remove the ECT switch with the engine cold.
2. Suspend the ECT in a container of water and then heat the water.
3. Heat the water and check the temperature with a thermometer.
3. Measure resistance between terminals A and B.
here is the diagram they show
Old 02-22-2006, 12:44 PM   #10
nonovurbizniz
If you jump the connector for the ECT switch and the fans come on there is NO OTHER PART OF THE SYSTEM ENVOLVED.
THE ECT SWITCH IS BAD.
That or your car magically NEVER heats up to over 150 degrees or so.
The only thing my recomendation could have misled him to was replacing the fan motor...
and dime to dollar it's one of those two parts anyway.
And I'd hope that he'd just direct power the fans prior to replacing it on an assumption that it was bad.
Old 02-22-2006, 03:17 PM   #11
ill fix them both if needed. the damn civic only costed 300bucks.
